Discuss Can you help solve conflicting advice re adhesive depth? in the Tile Adhesive / Grout Advice area at TilersForums.com.
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully screwed in. The Tiler laid my 5mm hex mosaic tiles on a 2mm bed, so obvs wasn't going to drain.
I took them back up and spoke to AKW, who recommended I put down a 3mm bed adhesive, let it go off and then re-lay tiles on a 2mm bed applied at 90 degrees to the first one. BUT - the tiler says it's v hard to follow the profile of a tray with an adhesive spreader, and also that a thicker 5mm adhesive bed will come up and interfere with the grout.
So what to do? Feels like I can
a) instruct the tiler to lay the mosaic mats on a 5mm bed (or 3mm bed with 2mm on the mosaic mats) and hope for the best
b) Put down a 3mm bed as suggested by AKW and hope I can follow the profile evenly
or c) If what the tiler says is true about the skill needed to use a tile spreader, find some kind of 3mm mesh to guide an even application
At the moment I feel like my best bet is option b) because the tiler dislikes a) and I can't see a product that would satisfy c)...
Dan
Admin
5,039
1,323
Staffordshire, UK
Got any pictures of the said area?
Usually need a full bed of adhesive (so no air pockets after pressing tile down) from a thick-bed solid-bed trowel. Usually large round notches in them.
What bed thickness it leaves then though, not sure. A few mm at least so could you not just use a decent round notch trowel?
This is a special trowel to leave more adhesive down to get a good solid bed.
sheeted mosaics are usually laid on a 3mm notch and flattened with a good ol squeegeeeee... sorry did not mean to quote "dan" oooppps
Reply to Can you help solve conflicting advice re adhesive depth? in the Tile Adhesive / Grout Advice area at TilersForums.com
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
