Currently reading:
Best blade for mirrored metro tiles
Discuss Best blade for mirrored metro tiles in the Canada Tile Advice area at TilersForums.com.
Julian 'Farmer' Bonsall
Adey - thanks for the suggestion
Feedback for others was:
I would recommend the Marcrist CK 750. This is a continuous blade that will give a nice clean cut on most tiles. It is better if you can cut wet but it can also be used dry.
Diamond Blades | Amazing Prices for Diamond Blades to Buy Online | Pro Tiler Tools - https://www.*******************/categories/diamond-blades/diamond-blades--tiling-/marcrist-diamond-blades/marcrist-ck750-long-life-premium-range
Or if you can use a 115mm blade I would recommend the PREMTOOL Turbo Fastline blade. This is to be used dry and will give you a nice clean cut and should be a faster cut but is only available in 115mm.
PREMTOOL Turbo Fastline 115mm x 22.2mm Diamond Blade TUR115 | Buy Diamond Blades (Tiling) Online from Pro Tiler Tools - https://www.*******************/product/premtool-turbo-fastline-115mm-x-22-2mm-diamond-blade-tur115
If you did want to use a grinder the PREMTOOL will be one of the best for that and will also give a nice cut, it won’t last as long as the CK 750 because of how thin it is, you also need to be careful when putting the grinder down with this style blade as they are fragile due to how thin they are but that is what gives them such a good cut.
Tile Shop
Recent example of using cement based adhesive with mirrors:
mirror vs cement 1.jpg mirror vs cement 2.jpg mirror vs cement 3.jpg mirror vs cement 4.jpg
Reply to Best blade for mirrored metro tiles in the Canada Tile Advice area at TilersForums.com
