Discuss 1st Job - Brick bond set bathroom in the UK Tiling Forum area at TilersForums.com.
barclay1406
Hi Guys and Girls,
i've got my first job starting next week and its a brickbond set in a bathroom, i think the customer is removing the sink and toilet. But if they dont
is there any difference to setting out compared to normal straight set. Get your datum line then work out your cuts in the corners, around sink(if still in), toilet etc??
Wasnt sure as being brick bond, what measures ok on one line of tiles might not on the above or below line of tiles if you know what i mean (hope that makes sense)
Also i know you should start with the focal point of the room but as you work through the door the wall in front has a window and the wall on the right has a bath so should i use the bath to get my datum line for heights and the window for widths??
Not sure on size of tiles except they are longer than they are wide so like a rectangle
Thanks in advance for any help
Steve
StevieBoy
Hello - always always always try to get the sanitryware taken out, that way you will have a clean run throughout - otherwise, especially half bonding, you will definately have a nightmare on your hands especially seeing as it is your first job.
I would personally always start with the window wall, centering the window checking cut sizes in the corners, then when you turn the corner put a tile which was the same size or near abouts as the offcut from the one previous. Then it appears that the tile has turned the corner effectively.
You will only be able to do this on 3 walls if its a 4 walled room with usually a door frame in between.
And yes, you can come full tile off the bath, providing its set level or full tile across the bottom window cill - whatever works best for cut sizes etc.
Hope this helps.
StevieBoy
Thanks for your reply stevieboy, just to clarify with the tile round the corner, if i had say a 300mm tile and the cut into the corner was 100mm, could i not use the off cut of 200mm to come out of the corner?? or is that what you mean?
Many thanks
Hi again, yes you thats sort of what I meant, but I would put a line across on the next wall, measure out from the corner say 180mm, put your full ones in then use that 200mm offcut to do that corner.
Hope that makes sense
Reply to 1st Job - Brick bond set bathroom in the UK Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
Hello, I'm just a home owner who doesn't have much experience with tiling but I'm looking for advice on fixing a few problems that a professional left me with. He of course has not responded to...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
