Discuss Tile moving and grout breaking in the Tiling on Underfloor Heating area at TilersForums.com.
58
Birmingham
Hi fellow forum dwellers, am a distraught customer looking for some advice.
We did an extension and got water pipe UFH installed throughout the ground floor close to 100sqm. The WFH was left to dry for 4 weeks before the tiling was commissioned. We purchased glazed porcelain tiles from TilePlus in Oldbury. The store were made aware about the UFH. The tiler was a recommendation and we had seen their work. The work that I saw was on a standard floor (no UFH). The tiling was done in July and no care was taken to ensure no one walked on the tiles before the tiler said so. We moved into the house in first week August. The tiles felt good to walk on. Once the cold started kicking in (around Oct/Nov), we followed the instructions provided to start the UFH and increase the temp by 1 degree.
In Nov I started noticing the grout broke but ignored it as it was just the one tile. As the months went by the grout came off from other places. Noticed tiles making noise as I walked over them. Started with a couple and now I have a floor of tiles that are making noises at various places. Called the tiler and the store to let them know about the issue. The store have passed on my details to the company that manufacture the adhesive (Palace Chemicals). Currently waiting for them to call me.
The tiler got defensive and is blaming the adhesive and UFH material. I am afraid that he is going to shrug any responsibility on this. I did pay cash (some via bank transfers) so don't have a VAT invoice of the work before anyone asks.
Where do I go from here? Any pointers will be appreciated.
Anthony
153
Coventry
What type of screed was it? Did the tiler ask you? I’ve just chopped up a floor on top of ufh,yet again
58
Birmingham
Hey @Anthony thanks for the reply. Am trying to find out the details of the screed. I had it written down but changed phones so lost some of the messages. The tiler, the supply company all were made aware multiple times of the UFH system.
Anthony
153
Coventry
This is on water fed ufh. This was done 2 years ago by someone else, if the floor is not sanded,and primed twice the tiles will eventually de-bond,this still happens regardless of ufh.
TKD Tiling
There are multiple reasons why this could happen, I don’t think you’ll find the answer on here.
31
Bristol, UK
Hi, Lots of possibilities, but with a bit of investigation, solvable...if you lift several tiles and the screed is cracked, then its the mix of the screed thats caused the unbonding...What was the room temperature when the tiles were fixed, hopefully above 5 degrees C the whole time, otherwise the adhesive wont bond... depending on type of screed, was it prepared/primed properly?..depending on size of floor, are there expansion strips in the appropriate places...Are there expansion gaps around the edges?..Possible adhesive mfg problem, but for the adhesive and grout to both unbond would be unusual..That is pretty much all I got.. Good luck...
Reply to Tile moving and grout breaking in the Tiling on Underfloor Heating area at TilersForums.com
