Currently reading:
Anhydrite screed prep
Discuss Anhydrite screed prep in the America Tile Forum area at TilersForums.com.
A simple question I'm struggling with.
Up front, it's a self build - my 4th, so done a fair bit but 1st time using anhydrite.
Screed down for 4 years+. Prepping for ditra. Started sanding with 40 grit using 6"festool orbital to remove laitance - solid - (so may have to use diff tool).
Issue I have - surface (when sanded with 40 grit) is a tough mushroomy colour - I can see whitey/ creamy colour aggregate beneath it where the air bubbles have burst.
Before sealing do I need to take off top mushroomy coloured surface to reveal agg beneath? -
Mushroomy surface is solid and we'll bonded to agg beneath - hard to even scratch it with screwdriver - my common sense brain is telling me that primer will bond well with top surface as is - so why remove and expose the more fragile agg beneath.
Appreciate your thoughts
Si
Dave
Subscribed
389,894
1,000,000
Co.Durham
Dave,
Wet ufh. Pressurised but not commissioned - I know ideally should commission b4 flooring but passive House insulation level and decided to use infared panel heaters combined with log burners and mvhr instead of gas boiler - using ditra in case do commission later on.
Floor is dry as a bone and (mushroom coloured) surface rock hard
It really needs it’s first heat into the screed imho.
As for the laitence , if you contact a flow screed pourer etc , most do a sanding service.
Understand that point re first heat: taking a chance on basis that any subsequent expansion & contraction will be similar to initial if starting from similar base temp (as ufh wouldn't be needed that often - installed it as retro fitting not poss).
I'm happy to do the work - it's part of what I do - just don't want to remove what I think is a good solid bondable surface - guess my concern is that primer won't penetrate surface & therefore surface liable to debond from the screed - maybe just overthinking - wouldn't be first time.
Ajax123
1,213
Lincolnshire
To use “traditional” prep methods The surface needs to be clean sound and absorbent. As the surface is currently solid it is definitely sound. Clean … well that’s fairly straight forward… A simple test for the level of absorbance is the water drop test. Get a few drops of water (you could use perhaps a spent lateral flow test bottle or similar) to put a few drops of water on the surface of the screed. It should soak in pretty much immediately. This, when you prime it allows the water in the primer to dial in pulling the polymer in as well. If the water sits on top of the surface for more that a couple of seconds it’s not absorbent. You can get specialist primers for non absorbent surfaces but I’ve never had much success with them. So you are best to sand/grind it to open up the surface a little and make it more absorbent.
Alternatively you could use a pressure sensitive vynil flooring adhesive to stick down the sites matting.
Final alternative you could use bal flexbone and avoid any prep at all.
Dave
Subscribed
389,894
1,000,000
Co.Durham
If you heat slowly then it should be fine. I would deffo sand it though for an acrylic primer method.
Cheers👍
Passes water drop test no prob. Gone for a Weber primer/ sealer & SPF.
I'll crack on with the 40grit as planned
Cheers👍
In case it may help someone I ended up using a grinding cup on a 4" grinder attached to hoover via a dust collector. I had forgotten I had these. Took no time at all just a matter of keeping the grinder level & moving at steady speed - backwards & forwards easier to control the grind that arcing from side to side.
Cheers for the advice - always grateful when people give their time for nowt to save others wasting theirs👍
L
Larsters
We have a new Anhydrite screed floor with Wet Under Floor Heating and planning to stick 60x60 Ceramic Tiles on this. The floor is being sanded on Monday and then the question is whether or not we need to prime the floor before tiling?. The floor has not yet been commissioned. We have had a lot of conflicting advice regarding the primer Can any one tell me step by step what I need to do to ensure I do things in the right order? TIA
Ajax123
1,213
Lincolnshire
Commission heating before doing anything. Check its dry, sand it, vac it, prime it with an acrylic or sbr primer, then tile it using either a gypsum based tile adhesive direct to the screed or a gypsum based adhesive to stuck down an uncoupling membrane and then a flexible cement based adhesive on top of the uncoupling membrane.
Reply to Anhydrite screed prep in the America Tile Forum area at TilersForums.com
