Currently reading:
What tile adhesive should I use for large porcelain tiles?
Discuss What tile adhesive should I use for large porcelain tiles? in the Tile Adhesive / Grout Advice area at TilersForums.com.
I am planning on doing my bathroom up in January so I'm needing to get everything bought before. I am using 600x600 porcelain tiles for the floor and 300x600 porcelain tiles (3.4kg a tile) for the wall, I know it will be powder tile adhesive required but I cant find any which states it would suit these tiles, it will need to be water resistant/ waterproof and these will be going onto moisture resistant plasterboard.
Thanks in advance
Dave
Subscribed
389,894
1,000,000
Co.Durham
Thanks in advance
Most cement based adhesives are suitable for porcelain but if you get an S1 , it will suffice for both wall and floor. Use a suitable backer board for the floor and new PB for the walls will take the weight.
Magic cheers, just now the floors are chipboard so what kind of backer should I put on top? All walls will be new 12.5mm moisture resistant plasterboard
Let us know you get on , maybe even share some pics. 👍
Just had a look and I think 'BAL Rapid Flex One Adhesive 20kg' would do the trick, do you agree? (see attached data sheet). Would this work onto chipboard? (I know its recommended to use hardie backer). Also what notch type and size do you recommend for tiles mentioned?
  • BAL-Rapid-Flex-One.pdf
Dave
Subscribed
389,894
1,000,000
Co.Durham
Yes that’s fine and don’t tile directly to chipboard as its a particle board and not stable to adhere to o. Trowel size. 10mm.
That’s the finished tile adhesive depth once the ribs are compressed.
Spot on, last question Dave haha. For trowel should U use 10mm square or 10x20mm U? (see link)
Vitrex 6, 10 & 20mm Combination Trowel 11 x 4¾" | Tiling Trowels & Spreaders | NoLinksToThis
That is 10mm height x 20mm width and also 6mm high x 10mm wide. Would the 10mm height x 20mm width be suitable for my 300x600mm tiles on wall and 600x600mm tiles on floor? If not can you give suggets what type of trowel and what size please.
Dave
Subscribed
389,894
1,000,000
Co.Durham
All fine. 👍
Reply to What tile adhesive should I use for large porcelain tiles? in the Tile Adhesive / Grout Advice area at TilersForums.com
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are porcelain. I’ve just got to the end of my bag of Mapei flexible rapid set tile adhesive (powdered)...
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log burner on a plaster render on blockwork wall. I’m planning to score and scrape the paint off the...
