Currently reading:
Bathroom wall tile repair, unable to match tile size.
Discuss Bathroom wall tile repair, unable to match tile size. in the Canada Tile Advice area at TilersForums.com.
Dave
Subscribed
389,894
1,000,000
Co.Durham
In 2014 I had my bathroom re-titled. I'm having my shower replaced and some of the tiles need to be replaced. The tiles on the wall are white gloss tiles 248mm x 328mm (purchased from ToppsTiles). The only size I can locate is 250mm x 330mm. Does anyone have any suggestions of how I can get around this problem without having to re-tile the entire bathroom.
You could try a wet cutter but you might get minimal chipping, how many is there to trim. ?
Graham171
You could get them water jet cut. Worth pricing first.
Thanks for suggestion, but you would loose the bevelled edge of the tile, I'm going for small mosaics
[automerge]1602064041[/automerge]
Why so many to change a shower?
That’s 3.3sq m!
Is the plumber heavy handed?
Usually if changing a valve it’s only a couple of tiles, often this can look good by making a contrasting ‘patch’ as you suggest maybe with mosaics.
The shower is actually a wet room and it looks as if there could be soem water leakage behind the tiles.
Reply to Bathroom wall tile repair, unable to match tile size. in the Canada Tile Advice area at TilersForums.com
Hi, long time lurker, first time poster. Over the years I've used the good advice that I've read on this forum but with my current project I am a bit stumped. I am renovating an ensuite, it's...
  • Sticky
