Discuss Levelling Systems - What do YOU Recommend? Which brand and why? in the Canada Tile Advice area at TilersForums.com.
Hi Guys,
I have been tiling since i was 17 (im 31) I have been stuck in my way and to be honest with you ill self level usually in a smaller area and build up with adhesive the majority of the time. This year i want to increase my speed and better my habits and i have heard the floor levelling systems are good and speed you up and take away any lipping with ease (I am in no illusion that i would not have to build up with adhesive underneath still)
anyway, I have a 90 sqm metre Marble floor to lay and i would love to try these out for the first time. I Start Monday....
Any advise on what you would use/recommend and why?
With a marble floor get prep 100% and don't build up adhesive and no need for leveling clips. Wedge type will scratch stone.
I was planning on using S.compound before hand in the lower areas and when i say build up with adhesive, I mean within reason! Good point on marking or wearing the Marble. I wont try the levelling system on this particular job.
I would still like the recommendations on the levelling systems?
Bill
No need to use clips with stone as the stone is less likely to 'bend' when clips applied like bowed porcelain does.
As for clips on porcs ... I now get the RLS block type from Italy that have thin bases so no need to use as much adhesive in the build up.
Work out cheapest other than direct from China and the quality is perfect. Buy 2000 at a time for the best saving.
Reply to Levelling Systems - What do YOU Recommend? Which brand and why? in the Canada Tile Advice area at TilersForums.com
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
  • Question
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
