Discuss Advice please. What board to use to level wall and tile on? in the Canada Tile Advice area at TilersForums.com.
Deleted member 53336
I use 10 mm jackoboard .
Using cement based adhesive dabs . 15 per board then when adhesive is dry drill through adhesive spots and plug and screw using jackoboard washers .
Google., Jacko board, wedi board ,dukaboard, and refer to their fixing guides not some chancer on you tube
Thanks, will checkout what you have suggested.
Reply to Advice please. What board to use to level wall and tile on? in the Canada Tile Advice area at TilersForums.com
  • Sticky
  • Question
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few ways to fix tile to bathroom walls. First you need to prepare the walls for tiling. Note that...
  • Question
  • Question
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log burner on a plaster render on blockwork wall. I’m planning to score and scrape the paint off the...
