Discuss Floor and wall advise for bathroom re furb.. in the Canada Tile Advice area at TilersForums.com.
Hi Everyone,
I'm after a bit of advise regarding my bathroom which I'm re doing.
Several questions, I'm afraid!
1. When i took the old tiles off the floor, they pulled off a bit of the surface of the backer board in places, upto a few mm. This is well fixed down, so don't want to remove if possible. Can I just use something like self levelling over the top to prepare for new tiles?
2. I've re plasterboarded most of the area, is it ok to tile straight onto this or will it need priming? Tiles are large 600 x 600.
3. One small wall I'm hoping to leave, this is skimmed painted plasterboard, what prep.would i need to do to make it good for tiling?
4. Best adhesive to use?
Any help greatly appreciated.
Benny
Hi Benny,,
you will be ok to level over the backer boards if they are secured (sounds like they are)
you are using a large format tile on your walls which will need to be powder adhesive either rapid setting or standard set (depends on how long you wish to wait to grout)
Plasterboard will need to be primed as best practise when using powder
the painted wall will need to be prepped.. you could apply a thin layer of adhesive, let it cure then scrape off which will bring the paint off or you could scribe it with a blade..
Other wise you are simply applying adhesive to the paint and not the actual substrate
I can throw some brands of adhesive to you if you like which would make the job easier
Hi Dave,
Thanks very much.
Yes, adhesive advice would be great, also what should i use to prime plasterboard?
Cheers
Benny
I would use Bal Flex-One as this has extended open time and adjustment time but you can grout after 6 hours
a tilers primer will be ok, or sbr but this is more expensive as it can be used for different things such as making slurry mix etc
just don’t use PVA
Reply to Floor and wall advise for bathroom re furb.. in the Canada Tile Advice area at TilersForums.com
  • Sticky
  • Question
10 Tiling Tips for Fixing Tiles to Bathroom Walls = From UKTilingForum.co.uk There are a few ways to fix tile to bathroom walls. First you need to prepare the walls for tiling. Note that...
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
  • Question
