Discuss Tiles to ceiling pool in the Canada Tile Advice area at TilersForums.com.
chas
Ireland
I know next to nothing about this but I think someone who may answer will need more information . Firstly tile type and size , height of ceiling above ground and any other relevant info you can think of .
Tiles to ceiling are a 50*50 zellige hand made tile. Height from pool deck to ceiling is approximately 2.5m.
At present ceiling is the underside of a concrete slab. 2 options either prime it or apply cement board or similar.
In the first instance I would go direct to my chosen adhesive company and get their rep to visit site and spec the job, then reassess it.
And I’d probably approach another adhesive company too, just to compare notes, and take it from there.
ultimately it’s their products you’re going to have to rely on.
Also maybe approach someone like wedi, and see if they have a solution.
it’s not the kind of work I’d be prepared to do without support from manufacturers.
chas
Ireland
I had arex out to site but they maintain that because we are fixing to a ceiling it goes against building regs . Even though the adhesive should be ok they will not stand over fixing to a ceiling.
Reply to Tiles to ceiling pool in the Canada Tile Advice area at TilersForums.com
