Discuss Bought a cordless grinder, but what way to cut? in the Tiling Tools area at TilersForums.com.
What way does your grinder cut?
  • Blade on left, debris coming towards you
    Votes: 1 50.0%
  • Blade on right, debris going away from you
    Votes: 1 50.0%
  • Total voters
tommyzooom
1,083
Ireland
So I bought a Makita 18v grinder, and it could be a game changer.
I'm using a Marcrist akkumax blade after being recommended one on here. So far so good.
The only drawback is I'm coming home dustier, even though it's cut outdoors, but the blade as supplied is on the left, throwing the dust towards me.
I'm thinking of rotating the headstock, so the blade's on the right, which will throw the dust away.
Who's done the same?
Just rotate guard to see how it feels before voiding your warranty, sure switch will be underneath, but good way to try.
It’s typically a stone masons way of using a grinder, it’s not only safer if it kicks back, it throws dust away from you and is easier to see cut line.
And tbh you can control the blade far more easily than when pushing.
I had been using a grinder that way for years until I moved over to thin porcelain.
Confused now as that's how I see the blade as it is normally in right hand, flip the guard and turn it over then you'd have to look over right hand....no?
No 😊 as you pull grinder toward you, your line is visible between blade and stock, the back left side of blade, which when pulling, is actually the leading edge of the blade, cos you’re cutting backward.
I’m sure not all stone masons are doing it wrong mate. 🤣🤣
[automerge]1569710683[/automerge]
Yes when you’re pushing, as long as your blade is to the right of the line you can see it, (not always possible to be on the right unless you compensate with line measurement) but if you are, you’re stood to left of grinder, which means it’s not a natural position to be in to push forwards in a straight line.
Therefore the stock can fluctuate in its position cos you’re pushing a heavy weight forward against the blade.
Whereas, when pulling, the weight is pulling the blade, therefore pulling in a straight line is easier than pushing in straight line. 🤣
It’s easier understood whilst trying it or being demonstrated mate.
And anyway, if it snags while pushing, the grinder is ripped from your paws, taking it god knows where. If you’re pulling and it snags, far less likely because of angle of stock in relation to wheel, the grinder is forced into your body and instinctively your grip is tightened and makes for a much safer recovery.
Any more questions mate? 😁🤣🤣
Spare Tool
Good explanation but I'm too long in the tooth to change my methods now I think... 😂
Reply to Bought a cordless grinder, but what way to cut? in the Tiling Tools area at TilersForums.com
You're browsing the Tiling Tools category on TilersForums.com. Find the correct trowels to use with which type of tiling. Find advice on lash clips and levelling systems and more.
