Discuss Am I missing out not using levelling clips in the Canada Tile Advice area at TilersForums.com.
Waluigi
I’ve done a couple of porcel-thin jobs now. Not on the scale of some of the people on here, just the small 120 x 60cm tiles. There’s no way I’d even attempt this type of job without them. That’s wall tiles
I’m doing some 70 x 25cm ceramics next week and I’ll be using clips on these too.
Job after that is some small 40 x 20 white tiles. No need for clips IMHO.
This has been debated many many times on here. The best thing for you to do is get your self a starter set with enough to do a job or whatever you like and make your own mind up if they work for you. Bare in mind they will take a bit of getting used to. Next question which brand ? Personal choice but pro tiler tools own brand seem to get some good reviews I'm sure they have a deal for you
Boggs
1,118
Uk
I shall go and have a look, they are just down the road from me.
Got some big (for me) tiles coming up so will give them a go.
Want a new cutter too as my Rubi is getting tired now.
33
318
Rochdale
Just did abit of practice this morning with the premtool like waluigi recommended, they’re spot on!
(The tiles are on paint and mdf board, i know...just practice) ;)
Waluigi
im doing quite a big order today with our friends at protiler. the clips will be in the order - are there any tips for using them? i.e. are the sizes the same as normal spacers 2 / 3 mm etc
Use the 1mm clips and use your own spacers.
Premtool have a couple of length clips for different thicknesses of tiles. That’s all you really need to think about.
The substrate needs to be just as flat as before clips came out. I tend to get my tiles pretty much bedded in and just use the clips to pull in on that last millimetre or two. Clips are designed to hold everything together until the adhesive sets.
Just had a small delivery of clips from PT Myself . These are the ones I mainly use.
Blunt Tool
If you do your own prep ( installing Cement, foam or plasterboard on walls or boards on floors and screeds) then you take your time and get it right so you don’t need clips if the tiles are good. If you have bowed tiles then clips can help straighten tile till adhesive has a chance to dry and fix-in place permanently. If the in situ walls are to be used then clips can help with lipping but you must make sure you are not creating voids behind tiles and if walls were that bad then would be better to fix first then no need for clips. Clips are in my van only for odd occasions, just another tool that is an option when weighing up sub surface, materials, tiles etc
Italy
Never had a problem before the came out ,dont use them now,sometimes creates voids when using them ,ive been told
you two are pro, you do not need clips.
clips are for apprentices ... ;)
Reply to Am I missing out not using levelling clips in the Canada Tile Advice area at TilersForums.com
  • Sticky
  • Question
