Discuss No More Ply for laying 600x300 porcelain in the Australia Tiling Forum area at TilersForums.com.
Colo
233
Durham
Hello,
I am planing on using no more ply over my existing 18mm flooring to lay 600x300 porcelain tiles.
Would there be any benefit in laying 2 layers of the 6mm no more ply to create 12mm covering.
Will this make the floor stronger or is the 6mm enough.
The joist are 8x2 at 16inch centres with a span of 10ft. There is no noticeable deflection when tested with a laser and the 18mm floor is in good condition
Any advice is appreciated.
H
hmtiling
Hello,
6mm nmp will add a bit of strength to the floor which i'm assuming is chipboard. 2 layers will definitely add more strength. depending how bad the deflection is i'd consider adding noggins and more fixings or using Blanke Permat.
Cranbrook
Hello,
Just checking but you do realise you can get NMP in 12mm rather than having to put 2 layers of 6mm down?
H
hmtiling
Id say only marginally, and with joists at 400 centres like the Op has then 12mm boards would be sufficient, in my humble pinion of course :)
Actually, if you read nmp's literature then you'll find that overboarding with 6mm and 12mm adds the same strength according to them. Cross laminating them would add far more strength in my opinion. To strengthen the floor permat would be the way to go
H
hmtiling
Cranbrook
Cheers for the help lads. The reason I wanted to double up the 6mm is that it is much more dense than the 12 mm and I thought it would give a stronger floor.
Another option would be to put 12mm ply down and tank it. Does any one still use ply.
No tiling on ply is a thing of the past.. if you are happy with the additional height, just put one 12mm NMP down and you'll be sorted, but as others have said, if you dont need the height, one 6mm NMP should suffice
H
hmtiling
If you really want to strengthen the floor go with permat. It gives a 10 year deflection warranty
Colo
233
Durham
Thanks for the help I really appreciate it. I have just looked at that Permat and its only 3mm thick I have read their claims but I do not think anything 3mm is going to add much strength.(probably due to my inexperience). I am really struggling to get my head around these modern materials.
I think I would probably be better off with 6mm No More Ply as you said earlier.
What would you think about using 12mm plywood with Ditra Matting.
I do appreciate any advice from you lads.
H
hmtiling
The 6mm nmp should be fine. Permat is an amazing product and definitely superior to nmp in this situation as it's a decoupler too. Make sure the sub floor is screwed not nailed down and use a decent s1 or s2 if you're worried.
Waluigi
After reading your first post and checking the joist sizing and span I don’t think you have anything to worry about. As mentioned, 6 or 12mm NMP, HB or even Aquapanel. Glued, screwed and taped with alkaline resistent tape if the manufacturer recomends it.
I haven’t used NMP before but if you tile onto HB or Aquapanel then the tile, Adhesive and board will be Monolithic which is what you want.
Time's Ran Out
Cheaper/better alternatives.
Which are?
There you go.
Raccus
uk
Interesting thread. On an upstaris bathroom with suspended wood floor, i was planning to use 18mm marine ply or wpb (is one better than the other). But seeing this, I'm wondering if this nmp equivalent in strength? Ideally wanting height gain to be as little as possible. I'm inclined to gather from this thread that 6mm nmp would be an alternative. Am I wrong, have i missed something, or is the nmp in addtion to the 18mm ply? (Though in that case it would make the no more ply name rather misleading!) Also for 60x30 porcs.
Reply to No More Ply for laying 600x300 porcelain in the Australia Tiling Forum area at TilersForums.com
