Currently reading:
Under floor heating, Hardie vs Ditra
Discuss Under floor heating, Hardie vs Ditra in the Tiling on Underfloor Heating area at TilersForums.com.
R
robbieraven
Hi Guys,
Opinions please, upstairs bathroom, brand new 22m chipboard, new install. I have always gone with 6mm Hardie Glued and screwed, then cleaned up acrylic primed and wire layed on Hardie and taped down, then latex ed over with 2 Part SLC, then tile?
Customer/electrician has suggested Ditra then Wire then Tile, I always like to SLC my UFH wire/matt before tiling. I can't see the logic in pouring leveling compound over Dita as surely you'll lose the whole purpose of the decoupling membrane?
Thoughts please not doubting myself just can't see the logic in his option?
illlf ditra is being used then should be on top of ufh and latex.
if floor is deflection free then thermal board, ufh, latex then tile would be my preference
if The customer wants to add uncoupling into the job then I would board with your hardie then fit a system like ditra heat, or vario pro, several others available. The wire goes into the mat then tile straight ontop
Reply to Under floor heating, Hardie vs Ditra in the Tiling on Underfloor Heating area at TilersForums.com
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
