Discuss Which of these tile levelling systems to purchase. Cost Vs Quality in the Canada Tile Advice area at TilersForums.com.
jimsters
Hi
I know this has been discussed a few times but im stuck as to which to buy.
Ive used the twist screw on type before but i thought id pickup one of these systems.
Which is the best for quality if cost wasnt as issue.
Which is the cheapest but still good.
Which is the best overall value & quality?
Here are the ones ive looked at. Too much choice.
Any advice.....?
Raimondi Floor Tile Levelling System RLS
Wedges can be reused.
Price is roughly about £54 for 100 wedges, 100 clips and the pliers.
coverage - not sure compared to others.
Genesis
blocks can be reused (i think)
price is roughly £48 for 200 straps, 100 blocks and pliers.
Rubi tile levelling
Caps can be reused ( i think)
price is roughly £50 for 100 caps, 100 straps and pliers
Mustang Tile Levelling
blocks can be reused i think
Price is roughly £58 for 100 wedges, 100 spacers and pliers.
Bright Ideas - I cant find their system on their website?
Vitrex lash system
wedges can be reused
price is roughly £25 for 150 wedges and 150 spacers.
PLS perfect Level Master
Price is roughly £75 for 100 wedges, 100 spacers and pliers
thanks for all your help.
Blunt Tool
perfect level master for me hands down.. the clips are far better than ramondi. Ive seen a few now though its not cheap I know im getting my moneys worth.. the PLM wedges have 1 2 3 5mm steps on them at the front of the wedge as well. Ill send you a small sample I have quite a few
I use the mustangs, do like them, bought the pro kit but kept wedges (identical to PLM) and just bought 2000 clips unbranded off eBay for 40 and they are good!
Mark Frost
528
Aylesbury
the mustang looks ok but i seen plenty of clips breaking where they shouldnt which hardly no addy touching them.. have you had this problem?
Blunt Tool
No I've also got them 2mm and 3mm so that it acts as spacer aswell! I do take a small trowel (Raimondi olive) along edge of tiles to clear excess adhesive away! Think that makes a big difference and keeps tiles and joints clean
Deleted member 49260
Oh and lash clips once . They're total rubbish but I do like the yellow wedges for wall tiling to support the bottom row
I'm a DIY'er and bought lash because they seemed OK - but they are way too thick under the tile for easy use (for me at least) with anything under a 10mm trowel, using a 6mm trowel I couldn't get the clips in! Agree the wedges are great for spacers - I nip the flat end and as many steps off as I need to get closer to the size of spacer I need.
macten
1,158
Nottingham
I think the lash clips would be really good for large uncalibrated slate or something. the curved base would be able to sort the different thicknesses.
A reasonably local tile shop I use stock Siri smart level clips and wedges and I find them great - used 500 yesterday and only had 2 break on me and that was probably my fault.
Can't remember how much the wedges were as I've not needed to buy any more for a long time but I just got 1500 clips for £90
Wayne Wilding
Im torn between PLM and Mustang. PLM definitely better quality but for the money mustang do the job well too.
Ive tried Peygran too which are even more expensive than PLM and they are strong but are a right pain to snap off (takes 3 times as long)
I saw your video on that on twitter, Joe..... seemed a very clear winner out of the two....
Reply to Which of these tile levelling systems to purchase. Cost Vs Quality in the Canada Tile Advice area at TilersForums.com
  • Question
