Discuss Limestone Discolouration in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Back home now and had a closer look. I didn't pick up on the uncommisioned ufh part.
I'd say that it's primarily the additional moisture of the extended set not yet gone, and in part - moisture rising from the screed still.
Good sign is the dryness around the grout joints. I think this will dry out but could take quite some time yet...
For future - please use Ditra and a rapidset. That would mean you could fix safely onto uncommissioned heated screed and no risk of residual moisture lurking in the adhesive.
Fraser Tiling
598
High Wycombe
The underfloor should have been commisioned before tiling. I'm pretty sure this is the moisture from the screed trying to get out.
Thanks Chalker, that makes alot of sense, will check with the builder that the UFH was tested before hand, I must admit I cant remember whether I asked, to be fair with their experience they should know.
Do you think there would be any staining if the screed is the issue?
Fraser Tiling
598
High Wycombe
agreed, I would never spec a floor and not use a decoupler
J Sid
no, wasn't deemed necessary by the builder, dont think there would be an issue if it was used
Deemed not necessary by builder, his trying to save money and when it all cracks he will blame the tiler as the tiler is the expert and should know what to do.
If its coming from screed it could take many weeks to dry out now. Tell the builder, due to his insistence to not use a uncoupling membrane he must now wait until floor is completely dry be you can seal it. He must also keep everyone off it or it will get stained.
Fraser Tiling
598
High Wycombe
Thanks to everyone that's posted on my thread, confident we have found the cause of the problem.
This forum is a brilliant tool for just these kinds of issues, cant thank you guys enough.
Fraser Tiling
598
High Wycombe
agreed, often builders offer the customer the option, and depending on budget the customers have the final say.
Unsure of the details on this particular job, but you're right, ultimately it has fallen on my shoulders when shortcuts are taken.
Reply to Limestone Discolouration in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
  • Sticky
