Currently reading:
Encaustic Tile Procedure
Discuss Encaustic Tile Procedure in the Australia Tiling Forum area at TilersForums.com.
cowgomoo
Good Morning to you all, if you have time I would like some advice on encaustic tiles. I have seen them before but never worked with them and now I am in a position to possibly start selling them I want to get all my info right.
I have read the various threads here and understand that it is a specialised install but there are 1 or 2 things I would like to get clear.
Are they really suitable for a bathroom floor ? does the weight of them make the prep any different to that of a porcelain for a typical 1st floor / loft extension with wooden joists.
Are they a suitable tile for a busy kitchen - prone to heavy use with lots of food spills including oil etc etc.
Are they a lot more to install with all the sealing, drying, laying, grouting and sealing again - what do any of you typically charge per m2 for this. My client will mostly be in London.
Do any of you specialise in this install.
I am sure more questions will arise but this will get it going.
I appreciate all the help / advice you have given me in the past and look forward to your comments.
Cow.
Time's Ran Out
You can get pre sealed encaustic now which has made this product more accessible to the fashion industry we work in!
It's a product which has the aesthetic impact that clients crave but not always the practical properties that they want long term .
No matter how much sealing is done it's not a material I'd recommend for heavy duty areas where oil spillages are possible.
As for costs - treat as blotting paper stone - possibly day rates.
cowgomoo
Good Afternoon John,
thanks for the reply, I supply plenty of "encaustic effect " tiles in bathrooms and kitchen where the characteristics of porcelain come to the fore. Would you say that these were for specialist installers such as yourself ??
ow
Spud
I always get a least 2 coats of sealer on them before fitting them , I use a slower setting rapid like keraquick or similar I always dip the tiles for 5'seconds before wiping off excess water and laying them , you will hear them kind of fizzing when you dip the back of the tile in the water , I let them dry out for a couple of days before grouting so I try and plan to finish the tiling on a Friday where ever possible and give them the weekend to dry out ,
Final finish I usually give them another coat of sealer and once this is dried in I finish with Lithofin multi seal
Sealer I recommend for encaustic is fila fob
MTiler
I worked with Bert & May encasustics last year and just followed their installation instructions. They all had to be washed and left to dry out before installing. Easy to cut as theyre not hard, I just used a grinder so they didnt stain. They really soak up the Impregnator lol. They had to be left to completely dry out for 5 days before sealing. I used 1mm grout joints and grouted with Mapei KeracolourSF grout.
cowgomoo
This was last year, followed advice from threads on here.
Didn't water dip them before fix though, but did leave days to dry out after washing and fix to make sure no water left.
Good Morning Julian,
marvellous install, did you have to do any extra wall prep for these ? I know they are heavy and wondered what you were hanging them off.
Is there a re seal regime to follow as these will get very wet !!
Cow.
Reply to Encaustic Tile Procedure in the Australia Tiling Forum area at TilersForums.com
Hi all, I am planning to tile a full height panel of split face tiles to sit 3” behind a log burner on a plaster render on blockwork wall. I’m planning to score and scrape the paint off the...
Hello, I am a noob trying to tile our shower. Since the old tiles were taken off, some of that wall material has been taken off as well, so everything had to be smoothed. After smoothing with some...
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
Morning All! I thought it was about time to start a new Good Morning Thread. The old thread can be found HERE but is quite long so not as easy to find specific posts. So tell us what you are up...
