Discuss Tiling on asphalt screed? in the UK Tiling Forum area at TilersForums.com.
H
H.I.S
Hi All,
I am new on here, and have just discovered this great forum with lots of good advice.
I have been tiling for a number of years now, not as a sole trade, i fit kitchens, bathrooms and am also a plumber and do other general building work.
i am after some good advice,
i have a floor to tile soon and its a substrate i have never tiled on before,
the property is a 1950s build and the floor has (i think) an asphalt screed this is about 20mm+ thick a brownish colour and solid, smooth to the touch. this floor is to have insulation board electric ufh and then porc tiles, i am worried about bonding to this substrate and would like to know what surface preparation and primer you all recommend for this substrate?
Thanks in advance for any advice.
Ajax123
1,213
Lincolnshire
oh oh oooh! Are you sure it is asphalt. It sounds typical of an magnesite screed. If you have a moisture meter (electronic type) bung it on the screed and see what reading you get. If it is positive it is very likely to be magnesite and as such you will struggle like heck to get anything to stick to it. I usually advise digging it out and putting something else in instead. Alternatively I guess you could drill and fix hardibacker or something like that to it.
Ajax123
1,213
Lincolnshire
Not easily and safely. If it smells of bitumen it could well be that. If it were me I would SAFELY use a heat gun to see if it melts. This is Hazardous though as it will potentially catch fire if it is Bitumen based. If you do this be flipin careful. Safer way might be to pop to B&Q and buy a moisture meter. They are not too expensive. You might be able to "borrow" one from who ever you are buying the tiles from. Post some pics as well that might help to id the stuff.
H
H.I.S
Asphalt Screed 004.jpg I have just tryed to post pics as requested i think the files were to big, it has only let me add this one.
This is the small piece that i broke out from the floor, what you can see is its cross section (depth about 20mm) i have taken your advice and heated a small amount with my heatgun on a brick and it becomes quite soft when heated, then when cooled it is hard again, it also smells like bitumin.
Do you think this is conclusive that it is definately asphalt screed?
H
H.I.S
I have got 6mm insulation boards already for the job as i cant go any higher, i was going to try and key/scarify the surface what do you think? so i can use cement or rapidset mix with sbr as slurry coat, do i wait till slurry is set before fixing the insulation boards down with spf? i had got some instarmac ultra prime it fp to use as an acrylic primer thinking it would do the job, glad i asked the question on here first.
Ajax123
1,213
Lincolnshire
melting and smelling of bitumen is pretty conclusive I would say. Magnesite would just get hot and with a blow torch would give of a bright yellow flame. As previously said though it don't look like asphalt. My opinion use epoxy to seal whatever it is then use uncoupling membrane.
Reply to Tiling on asphalt screed? in the UK Tiling Forum area at TilersForums.com
  • Question
Hi all, I'm hoping you can help with some feedback, please My parents are currently having a new bathroom installed, all stripped back to bare walls and floor. The fitter has done/hasn't done...
  • Question
Hi, long time lurker, first time poster. Over the years I've used the good advice that I've read on this forum but with my current project I am a bit stumped. I am renovating an ensuite, it's...
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
