Discuss SLC Questions Concrete in the Tile Adhesive / Grout Advice area at TilersForums.com.
Dan
Admin
Staff member
5,039
1,323
Staffordshire, UK
I doubt you'd need much there and if it cracked around the edge of such a small area it's not going anywhere. Just leave a gap for silicone instead of grout when tiling and don't worry about the SLC let that meet the edge.
..... Is what i would do.
Reply to SLC Questions Concrete in the Tile Adhesive / Grout Advice area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
  • Question
