Discuss Porcelain Tiles Unbonded in the DIY Tiling Forum area at TilersForums.com.
A
Asc
I have underfloor heating and a concrete floor. I cleaned the floor then PVAd it. I followed instructions on the bag of adhesive (cement based, highly polymer, modified, thin bed tile adhesive) The underfloor heating was turned off in advance. It was tiled using the trowel which was advised on the instructions from the adhesive bag (6mm square notched trowel). After around 10 days we heard some cracks and bangs but did not realise what this was. We turned the underfloor heating on, at the lowest setting after two weeks and we continued to hear cracks and bangs - we discovered that this was the tiles letting go. We have had to lift the whole floor, the tiles have come up with no effort at all. There is no adhesive stuck to the tiles (38m2 of 600 x 600 porcelain tiles) but it is stuck well to the floor. We have spent days taking the adhesive up with a hammer drill. On inspecting the granite tiles in the bathroom today they have also done the same and we are also going to have to take all these up and remove the adhesive from the floor.
Does anyone know what the problem could be?
The tiles appear to be quite powdery on the back - could it be this?
Or is it a problem with the adhesive?
Or something else we've done?
We have recently laid tiles ceramic tiles upstairs using different adhesive and have had no problems at all. (Although there is no UF heating there)
Would it help to clean then PVA the backs of the tiles before trying to lay them again?
Thanks for any help anyone can offer.
A
Asc
A
Asc
The tiles were not back buttered - should they have been?
It's a solid concrete floor which has been in for four years - the underfloor heating went in at this time and was turned on Dec 2015, it was only turned off to tile.
We turned it on at the lowest setting after two weeks.
The tiles are porcelain.
They are very powdery on the back - could it be this?
What adhesive would you recommend?
MW Smith Ceramics
Q
Qwerty
That's a rapid set cement. As well as no back buttering, possible dust on backs of tiles and PVA used as a primer, my guess is that you have probably mixed the adhesive too stiff but maybe also left it too long between trowelling the adhesive and laying the tiles. Most rapids only have a pot life of around 30 minutes and an open time of around 15-20 minutes
MW Smith Ceramics
I think tiling directly onto 6mm ribs of adhesive with with 600x 600mm tiles is asking for trouble.......I would be working with a 12mm adhesive trowel on the floor and on the the back of the tile off the high spot in the floor then working with an edge off that......you need 100% adhesive coverage on your tiles, I your fixing method and and possibly the wrong adhesive have caused you the installation failure here......how did you manage to fix large format tiles onto a 6mm bed of adhesive ??....surely there was a few lips showing
Chalker
1,058
Tadcaster
The above post has been deleted.
This is not appropriate @Paul C.
Do not use the forum as a mouthpiece for the organisation that employs you.
tilersforums.com has no affiliation with Walls And Floors whatsoever!
Nobody has said anything against the supplier. I've had quite a bit from this supplier, with no problems. I think the problem is with wrong fixing and thermal shock!
If I buy a boiler or a bathroom from a merchant, they don't tell me how to fit it.
That's what professional tradesmen are for
Bill
We don't know if a pro was used yet - but anyway, even if they did it themselves, I would still expect a certain amount of help from the shop.
Not saying anything has been said against the supplier Chalker.
If you did not see what was posted, then please do not make assumptions, that's how things get misinterpreted.
The post was not malicious in any way.
Reply to Porcelain Tiles Unbonded in the DIY Tiling Forum area at TilersForums.com
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
  • Question
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are porcelain. I’ve just got to the end of my bag of Mapei flexible rapid set tile adhesive (powdered)...
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
  • Question
