Discuss New Build UFH Tiling in the DIY Tiling Forum area at TilersForums.com.
John Wingfield
Hi all
First post on here as need some advice. We are building a house and have got to the point where the floors need tiling.
The floor is a sand and cement screed that was NOT poured. It has been in the house since August.
The screed contains water based UFH which has not yet been turned on / commissioned.
I am going to be doing the tiling - done plenty before in previous houses, but never onto a screed with UFH. The chap in charge of the build has stated that we need to use a decoupling membrane on the screed to stop the tiles cracking.
I dont believe this is required, as the screed has had plenty of time to dry out (5 months) and I will have expansion joints between each room between the doorways.
Just after others experience / advice on this topic?
John
One Day
Your risk lies in the fact that the floor hasn't been commissioned.
Once commissioned, and cooled - the cracks, if any should happen.
If you are fixing a porcelain, or strong stone then you'll likely be ok - especially if you have bays and expansion joints in the screed already.
If you're fixing a weak stone - marble / travertine etc then definitely uncouple.
Look at the cost of a membrane - even Mapeitex (probably the cheapest option at the moment) and you weigh up - how much do I value my stone/tiles?
- am I prepared to risk it?
- is the extra outlay worth the piece of mind?
Many of us have fixed long-lasting floors without Ditra, but never onto uncommissioned screeds without Ditra.
John Wingfield
Not against it. I had heard from both sides re using it and not using. Obviously cost is a factor, so I wanted to ascertain whether or not it is truly required.
If I need approx 180SQM of Ditra I cant seem to find anywhere selling it less that £1300. That is quite a bit higher than 15%, plus I would also need to add some more thinset on to that cost, so Im looking at about 25%
If I was spending £4.5k on tiles the modus operandi would have to be:
1. Commission UFH
2. Decoupling mat
3. Tile ( with some appropriate expansion joints - taking into account the ditra.)
Also £1300 over the cost of the whole build ( guessing between £300kkish 2 storey , £180kish single storey? - very ball park ) is about 0.5% ish of total build cost? So in the grand scheme of things you might have a cancel one family holiday :0)
You see where I'm coming from.
Diggy :0)
John Wingfield
LOL....I will ring an find out. Will have to dig out all the invoices for materials.
I will put the matting in - you have all convince me. I will also ask that the UFH is commissioned first. I have looked around online and there are so many choices:
Bal rapid mat £1393
Ditra £1328
Tilemaster anti-fracture £1260
Durabase £1068
Plus Ardex AF200 x3 15L tubs =£230
What peoples thoughts on Durabase C++
One Day
Positives: Ditra is the original, without doubt the best and has zero history of failure. There is NOBODY with poor confidence in Ditra, whereas many of us remember the Durabase problems some years ago.
Negatives: It will increase your adhesive use by around 30% and raise height 4mm.
If you're not using Stone (which really benefits from Ditra) then I'd go with Rapid Mat - it's the easiest to use.
Reply to New Build UFH Tiling in the DIY Tiling Forum area at TilersForums.com
  • Question
  • Question
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
  • Sticky
  • Question
