Discuss How to tile an internal corner in the DIY Tiling Forum area at TilersForums.com.
slicendice
I'm just wondering how to tile round an internal corner in terms of how to butt the tiles up to the wall. As they say, a picture says a thousand words, so should I go for A or B:
And whichever option I go for, am I right in thinking that I'd need to caulk the join between the tiles that meet, rather than grout?
Thanks...
a technique i use is-
tile one wall, then spread adhesive on other wall, then before sticking tiles on adjacent wall put a bead of silicon in corner making sure it,s sticking to tiles, them stick tiles on wall so silicon is in contact with both sides of tile, but don't let silicon push out from behind tiles, then grout over the joint,
Bond
518
Highland
sorry, i do it on internal corner walls of showers, if one wall is a stud wall,it seals the corner, it and i'd rather look at grout in the corner instead of silicon.
Similar situation to doing external rendering/rough casting around window/door reveals where some will sandwich silicone sealant between the scratch and top coats, it ensures the seal movement joint is encapsulated. Then finish with an additional seal on top. I guess it’s down to what you have been taught. Preference etc.
yes but i have found that if the grout does crack then the silicon in behind stops the water penetrating, and i've went back to showers years after having used this method and and the silicon helps to stop the grout in the corner cracking. also no one wants to look ak a newly tiled shower with silicon in the corner, no matter how well the silicon is fitted.
Bond
518
Highland
In the situation discussed the grout is only cosmetic ,(on the surface, ) any movement, the grout will crack and fail, without comprising the integrity of the joint.
Once had a customer say, when l had finished a shower, “what’s that in the corner” it’s silicone sealant ( normal practice in the situation) bla,bla,bla, . “Don’t like it , get rid of it, l want grout”
Yes mam, using a double edge blade cut the silicone back to the corner , and grouted over to conceal the silicone. No problem.
If that’s what the customer wants.
Dumbo
As I said it's not just about the integrity of the joint you are meant to have a movement joint between two abutting surfaces to stop the installation getting stressed by movement between the two surfaces . Even In a dry corner it should be silicone to allow for movement between the two surfaces .
Reply to How to tile an internal corner in the DIY Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
  • Sticky
  • Suggestion
Post a New Thread for Each Tiling Job Completed. Rather than using the Show us Your Work Thread - which has more than 500,000 views, and thousands of posts to scroll through - we thought it would...
  • Question
  • Sticky
  • Question
