Discuss Herringbone bevel metro - what trim?! in the Canada Tile Advice area at TilersForums.com.
Deleted member 56490
Hi, my tiler has recently suggested that beveled metro tile, herringbone, half wall will not look good as extra grout will be exposed on the trim. I'm intending to use white tiles, dark grey grout and black trim. Would a box trim work to the highest part of the tile with the lower part just showing extra trim? Ie no grout buildup? Thanks, any thoughts ideas welcome. As I'm not doing it, also looking at the simplest method to not add too much extra expense for tilers time
Dave
Staff member
Subscribed
389,894
1,000,000
Co.Durham
Thanks - but as a tiler, you'd think acceptable/ok to do beveled tiles in herringbone with half wall trim? I'm guessing making it look good is all in how even/clean the top line of tiles is cut so that the trim doesn't rest uneven on the cut tiles?
It will always show on a bevelled edge , keep the grout lines against the trim even and a neat edge is about all you can do when trimming. It’s not something in bevelled tiles I’d like.
Reply to Herringbone bevel metro - what trim?! in the Canada Tile Advice area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
