Discuss Grout color changeing in the Tile Adhesive / Grout Advice area at TilersForums.com.
Mapei UK Marketing
823
Never happened this to me before but recently done a job.i used mapei grout beige color and after it dryed looked a bit diferent color in places like it was wet and not dry.left it even after a week and still the same.used clean water clean sponge everything done right.also scraped the area and grout again and now is right.
Any ideeas why did that happen?
Hi Mario, all,
With regards to Efflorescence - this is the migration of salts to the surface of the grout, which when the water evaporates leaves a whitish bloom.
Mapei Ultracolor Plus cannot itself produce this because we do not use Portland cement which can release the salts. This is not to say that this can never occur as Portland cement can be found in the adhesive or substrate but as before it cannot come from Ultracolor Plus grout.
The shade variation can be due to a polymer found at the surface which can be attributed to excess water, method or tooling of the joints. The higher the polymer content in the grout the higher the flexibility and water resistance. This can be removed by lightly rubbing with a fine sandpaper.
I hope that this helps! If you have any other queries, please do call Mapei's Technical Service Deparment 0121 5086970 (option 2), open 7am - 7pm week days
Kind regards,
Mapei UK Marketing
Dumbo
I
Hi Mario, all,
Kind regards,
Mapei UK Marketing
I just think that you should make grout which is less temperamental especially considering most tiles today are porcelain which don't draw any moisture from the grout therefore it is not hard to have excess water on the grout especially with slightly textured tiles on which Mapei ucp can be difficult to remove from to say the least.
I'm a reasonably competent diy'er & tiled a few bathrooms and kitchens over the years ( I'm 60). Patching just happened to me as yesterday using Mapei medium Grey 112 with grey 10mm porcelain slightly textured surface. Never had this before. I shook the bag but only mixed half, carefully weighed grout & water carefully measured, then mixed using a mixer ( drill attachment), left for a couple of mins and mixed again . Grout went on great and when started to dry, I used a very wrung out sponge (clean water) to carefully wipe excess grout off the tiles but not the joints. Wiped all over after about an hour - but again with only a barely damp sponge. All looked fine but this morning parts looked darker. I did try lightly sanding around one tile (to be covered by a mirror) and it did the trick but what a complete faff to have to sand more or less every joint to ensure an even colour, there has to be a better way and disappointing that Mape's answer is to resort to sandpaper. I did a metro tile spashback last year using silver grey - from Topps Tiles but cant remember the brand- not Mapei, was is a dark blue & white or blue & silver bag if memory serves. That went on using same method & dried perfectly and yet Mapei are peddled as the best grout on the market but with seemingly zero tolerance - even pro Tilers experiencing issues so it cant really be the tilers I wouldn't have thought.
Mapei UK Marketing
823
Good Morning,
As a general rule of thumb we would never recommend part mixing the grout as it is next to impossible to get the same quantity of the various chemicals mixed, as when mixed as a complete bag, hence the final finish appears patchy.
Julian 'Farmer' Bonsall
I don't think I am capable of grouting 5kg of UCP in one go by myself. I haven't had a problem personally and have used UCP for the few jobs I've the last year or so. I didn't know I wasn't supposed to only use part of the bag (I do my best to tip it end to end a fair few times before I use it).
Are these problems more likely with certain tile types ? Are certain Mapei adhesives less likely to be linked to this? (I used mapeker rapid set last time).
[DiYer]
Time's Ran Out
58423366-DF68-4104-B799-6C4B5DEE1ECB.jpeg Grouted in Tilemaster 3000 natural grey.
Reply to Grout color changeing in the Tile Adhesive / Grout Advice area at TilersForums.com
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
  • Sticky
  • Question
