Discuss Frame for large format tiles in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
Hello!
I have a dilemma, and if you could help me with advice, I would be very grateful.
I am trying to install a feature wall, with two 120x250cm porcelain tile format, LED lights around the tiles and also would like to have my TV mounted on it. The original wall is an exterior plasterboard.
The tiler that I talked to said he doesn't really do any joinery work, but he would be happy to give it a go. Now, I don't really know if I should trust him and go with him, or get a joiner to do the job.
Is this a big job or can be done pretty easy?
Does it mean a wooden frame screwed to the plasterboard behind, and then a backer board screwed onto the wooden frame, ready for tilling?
Thank you!
Virgil
PS: I still need to get a joiner to put some wooden panels after the tilling is done, but was thikng maybe to get him before the tiles to also do the frame?
I’m assuming you mean 1200 x 250 planks… I don’t really consider that are large format… long, yes, larg, nope. What sort of tile is it and how are you having it spaced?
It is actually 1200 x 2500mm, vey large tiles. I am only having two with a minimal 2mm grout lines. I am trying to achieve a bookmatch design.
Lou
Admin
Staff member
1,473
Staffordshire
Reply to Frame for large format tiles in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
Hello there, Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a...
