Discuss Floor tiling? in the Canada Tile Advice area at TilersForums.com.
Hi guys - I’ve joined this forum because I’m planning on attempting to tile my new build bathroom floor myself...but I’m pretty clueless. It’s got a level chipboard, is this ok to tile over or do I need an underlay? And with the toilet and sink, do I have to remove these? The builders have said they can be ‘lifted up’ but if I’m honest they’re diabolical builders so I don’t trust what they say as far as I could throw them. I know I need adhesive, tile cutter, angle grinder and grout but is there anything else I’d need? Any tips? Thanks 😊
Dave
Subscribed
389,894
1,000,000
Co.Durham
Hi. Yes you need an underlay. Hardibacker is one i use. (6mm). There is vids on YouTube how to install. If you have the option to remove sanitary ware then it no makes an easier installation for the tiling.
Reply to Floor tiling? in the Canada Tile Advice area at TilersForums.com
  • Question
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
  • Question
  • Question
