Discuss Exterior tiling area in the UK Tiling Forum area at TilersForums.com.
I'm putting in a proposal for a job oop north (Durham, I think that's up north, isn't it?). I'll be having to (if I get the job) lay an area roughly 10m x 6m with irregular shaped pieces of stone, basically it's a map of the UK made up of stone from the correctly corresponding areas. I'll get the stone and then have it cut and prepared ready to be laid. It's outside, going to be used to walk over and the area at the moment is just grassed over, they will be getting the ground sorted to make it suitable for the stone to go down.
My question is, I obviousley need someone to check that what has been put down as the base is correct and that it is suitable in every way for the stone to be laid so how specialist is a job like this? Should I just post it up on the Find a Tiler section, what sort of things should I look to in a company that offers to do it?
I'll build the piece but I'm not going to take a chance in the laying, I need a company experienced in this sort of thing but it's a case of knowing the right questions to ask them.
Cheers
Reply to Exterior tiling area in the UK Tiling Forum area at TilersForums.com
  • Question
I have moved into a new house and want to tile the downstairs bathroom walls. Its not a big room but my wife likes the idea of a feature wall tile and then a grey / white tile on the other 3...
  • Question
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
