Discuss Can you tile using anti fracture mat direct on floorboards? in the DIY Tiling Forum area at TilersForums.com.
Hi all, new to this forum and looking for advice / reassurance.
I'm getting my hallway tiled and it's an old house, built circa 1900. It still has the original floorboards and after getting a few quotes, the tiler who can do the job says I only need to put down anti fracture mats over the wooden floorboards. Others had said I'd need Hardieback over them.
I'm worried I spend all this money and the tiles end up cracking, but he reassured me that I only need the antifracture mats + the flexible grout.
Does this sound right to you guys?
Reply to Can you tile using anti fracture mat direct on floorboards? in the DIY Tiling Forum area at TilersForums.com
  • Question
Hi, Can't seem to find a solid answer as I realise so much depends on multiple factors. I'm planning to tile my kitchen floor with 8mm porcelain floor tiles (660x440mm). My kitchen floor is...
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
