Discuss Can A Skimmed Plaster Board Wall Support This Tile? in the Canada Tile Advice area at TilersForums.com.
finally found a tile i like but its porcelein.
it weighs 17kg per m2
will a skimmed plasterboard wall support this with adhesive?
thanks
iv seen 100kg tile
what I would like to know who are these quangoes and have they ever stuck a tile on to any plaster or even know what it looks likeThere is a lot of talk of weight limits on here for sure, and I'm sure it is British standards but I think it is a bit Ott. Perhaps if you were fixing to a skimmed ceiling but as said before, on a wall, the weight isn't really pulling on the plaster as such. Have you ever stuck a big tile on to a plastered wall and tried to pull it off, it's not about to fall off
was a bit of time that I wanted to tell you.There is a lot of talk of weight limits on here for sure, and I'm sure it is British standards but I think it is a bit Ott. Perhaps if you were fixing to a skimmed ceiling but as said before, on a wall, the weight isn't really pulling on the plaster as such. Have you ever stuck a big tile on to a plastered wall and tried to pull it off, it's not about to fall off
Reply to Can A Skimmed Plaster Board Wall Support This Tile? in the Canada Tile Advice area at TilersForums.com
