Discuss Asphalt roof. in the UK Tiling Forum area at TilersForums.com.
jstrats
Hello good people i have a job to quote which involves tiling an asphalt roof.
There are a number of issues to deal with and need your fellow expert opinions.
I haven't physically looked at the job yet, just getting email info and pics (see attached)
The client wants the current paving slabs removed and either replaced with slate or porcelain with a shingle border.
I have read that dark coloured tiles absorb more heat, would this affect the amount of movement, especially with the asphalt?
I had planned to put a slurry down and then use something like Fastflex.
How would you approach this job? I want to give him (and myself) as much info as poss before proceeding.
Many thanks,
Jamie.
The Legend; Phil Hobson RIP
Hi Jamie, exterior asphalt is not a suitable substrate to tile directly to. I have in the past done a few using a decoupling membrane, but things have moved on since then. Schluter do a complete balcony system, it may be a bit pricey though.
The most successful method I have used is a 65mm semi-dry screed over the asphalt, if you have the height to allow it.:thumbsup:
jstrats
Thanks Phil, i think the screed would be a good idea actually as the customer just sent me this message:
The tiles (concrete slabs) are glued with what looks like to thin lines of glue. I have pulled up one loose tile and taken photo which I will email you tomorrow from work - can't do it from here. It has left an indentation in the asphelt.
I am happy to go with porcelain. I would like the tile to be at least 15mm thick, but preferably more, so that there is a sufficient dip around the edge of the terrace for the pebbles/stones.
Phil what mix would you use for the screed and do you think it would adhere to the asphalt ok? I would be worried about it cracking, but i do need to get the level up somehow to allow for the shingle.
jstrats
Taking the tile thickness and adhesive bed into consideration i will only have about 40-50mm to play with, not sure if that is adequate for a screed? The client is also nervous about me doing a screed above his living room as he thinks it may be too much weight, i'm mot sure if it is or not to be honest.
Can anyone help out with this dilemma? I don't know which way to turn at the mo.
Reply to Asphalt roof. in the UK Tiling Forum area at TilersForums.com
