Discuss Ardex wpc application / batch size question in the Tanking and Wetrooms area at TilersForums.com.
after some advice please.
I’m about to apply ardex wpc to the hardi walls for a corner shower. I’ve applied a thick mix of ardex to the taped joints. I know 2 coats are required on the walls but as it dries so quickly, is it best to mix enough for the 2 coats or mix separate batches in case the ardex for the second coat starts to set in the bucket/ roller before the first is dry? Tia
Reply to Ardex wpc application / batch size question in the Tanking and Wetrooms area at TilersForums.com
