Discuss Any advice gratefully received ! in the DIY Tiling Forum area at TilersForums.com.
MisterP
New to this forum and looking for advice please.
I have approx 20m2 of white porcelain floor tiles to lay , Homebases 400mm square. I am an experienced DIY'er with plenty of tiling experience in the past. I like to research what I am about to do first, but with this job it's led to lots of conflicting advice. Could someone please advise on the following :
1. The best adhesive for the job. The floor is concrete. The tiles are to be laid in the kitchen.No UFH.
2. Do I need to prime the concrete first ? If so, could you recommend a primer ?
3. Exactly when to seal them - before laying , before grouting or both ? I know they have to be done after grouting too. And a recommended sealant please.
Thanks very much.
Reply to Any advice gratefully received ! in the DIY Tiling Forum area at TilersForums.com
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
Hi all, I'm hoping you can help with some feedback, please My parents are currently having a new bathroom installed, all stripped back to bare walls and floor. The fitter has done/hasn't done...
  • Sticky
  • Question
