Discuss Anhydrite screed........ in the Canada Tile Advice area at TilersForums.com.
Andy Allen
1,318
Gloucester
Currently working out a price to tile one of these screeds, last one I did must of been 10 years ago, and things seem to have moved on since then.
First off, what's the tile master anhydrite a Adhesive like.
The screed has UFH and there using a porcelain tile, on a normal screed I wouldn't bother with a decoupling mat with a porcelain tile, is a decoupling mat essential with these screeds regardless of the tiles.
And what do you use to sand the floor, looking to hire not purchase, floors about 45m2
The Anhyfix is ok Andy, still need to prime the floor.
Just not to the extent that you would if you were using a cement based adhesive.
Most people I know Mat it so they can use cement adhesive over mat.
I’ve sanded two of 50m2 and below with a flex, a grinding cup and decent vacuum.
If you hire one you can get a 60 grit copper plate apparently, that I’m led to believe is effective.
It would fit on to a regular cleaners buffing machine.
Or you could get a full blown grinding set up to hire.
Andy Allen
1,318
Gloucester
Tilemaster anhyfix is the best gypsum adhesive out there imo.
I always try to put a crack mat down and witch to cement based on top.
Is it definitely anhydrite?
Do you know who laid it?
Looks like anhydrite...
F
Flintstone
Anhyfix is glooopy it's a bit like ultimate to use but it does the job well. With porcelain I don't use any mat unless the screed is cracked or other issues. Personally I feel pumped screeds are growing in popularity massively so its worth the investment in a floor grinder. I use a 7 inch grinder with cowel and diamond cup. You can do about 50m a day without too much stress. Above that is a stand up machine like impish suggested but it's a big old machine. The BAL flexbone mat, yes it sounds alien but there a huge company they wouldnt bring it out if it was flawed.
How long has it been down ?
Fraser Tiling
598
High Wycombe
Just done 160 metre floor, laitance not removed for nine months.
My usual grit pad on rotary buffing victor 400 that would breeze laitance removal didn't touch it. A bigger heavier grit machine removed 6 square metres in two hours.
Customer had to descabble it to remove it in the end. Tore it to pieces in places but still struggled in others.
Used Kerakoll primers, adhesives, decoupler and addy to 15mm limestone.
No issues
All UFH too.
Good luck.
One last thought, any builder that skirts a floor before it's tiled deserves walking away from
Trouble
Cranbrook
No issues
All UFH too.
Good luck.
Trouble
This would have flown through it
Andy Allen
1,318
Gloucester
It's been down since the end of August,
UFH been on for 4 weeks...
Ajax123
1,213
Lincolnshire
This sander with a turbodisk attached will easily deal with the Laitence if its all like the pics. It looks pretty damp though so do a moisture test before you tile it. As for adhesives and ball suggesting they have a system that doesn't require sanding... well i doubt it...
Blunt Tool
No sanding, no priming, no adhesive (loose laid) is what they are claiming?
Ajax123
1,213
Lincolnshire
Ah I see. Loose lay .... yes that would negate sanding. I know similar systems were used in Germany but ive not come across them for several years. I think genesis did one as well.
Reply to Anhydrite screed........ in the Canada Tile Advice area at TilersForums.com
  • Question
Hi, I am planning on tiling my concrete garage floor with porcelain tiles. The concrete was laid down several years ago by a previous owner, and it looks like it was also polished and sealed -...
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
