Discuss ADVICE PLEASE! - First time tiling - Installing split face tiles in my bedroom in the Canada Tile Advice area at TilersForums.com.
Hi all,
I'm struggling to get a tiler in my area since lockdown so I have taken the bold decision to go alone as I need to get the project finished in the next month! I think I am prepared to start but I have some areas I'm not so clear on...
I will be starting by mechanically fixing 4mm Marmox boards to the wall.
  • Is a 6mm trowel correct for spreading the adhesive for the Marmox boards?
  • What is the recommended method for mechanically fixing? wait for the adhesive to set and then start drilling/screwing?
  • I have the washers, but which screws and plugs are recommended?? (dry lined/breeze block wall)
  • Should the washers sink into the marmox board to leave a flat finish for tiling?
With the split face tiles, I have some difficulties to overcome as well!
  • What is the best way to cut the skirting profile? Dremel rotary tool and a little diamond cutting blade?
  • I'm going to hire a wet tile cutter, but what is the best method for cutting a 42-degree angle (see photos!)
Any advice or recommendations very welcome! (or if you know a tiler in Southampton, even better!)
@Ben-gee @Harrybowling Thank you for your quick responses
The job i'm trying to match up with is from 2 years ago where the advice on here was to ensure the tiler overboarded due to the weight of these tiles per sq/m (nearly 40kg when adhesives factored in)
@Harrybowling Thank you for the idea with the skirting board being cut to the tiles own profile. Looking at how irregular the tiles are, it may be just as difficult, and I only get one shot at it! I'm going to buy some large diamond cutting discs and give it a go on some offcuts to see if i can cut a decent skirting profile into the tiles
Reply to ADVICE PLEASE! - First time tiling - Installing split face tiles in my bedroom in the Canada Tile Advice area at TilersForums.com
