Discuss Big clinker and porcelain tiles problem in the Canada Tile Advice area at TilersForums.com.
H
Hlm
Hello,
After a bit of help and advise please.
I've used the clinker before to cut porcelain tiles and it handled then no problems, nice clean breaks.
This time around the tile is denser, I've got to score slighter harder resulting in chips to the glaze here and there. Then when it's time to break, using a sharp slapping action, the tile breaks down to the last 3/4 and then the break swerves off.
The tiles are 600x300, trying to cut the longest length.
Any help would be appreciated.
R
Rizzle from the Portizzle
Hello,
scribe the face then take out of the cutter back edge the end of each scribe from the back with a pin hammer then tap the back of the tile in the middle with the pin hammer should break in two without sharding off
H
Hlm
Thanks for the reply.
Think I'm going to have to buy a wet cutter, I've tried different methods, tapping each end with the breaker but still the same break off.
widler
1,328
England
Unfortunately some of the porca are crap to cut,even with a mighty sigma :)
I've just done a 80m2 ish room,and nearly all the straight cuts just slightly snapped off line at one end,in more or less the same place,couldn't notice when the skirt was on but would pee you off if you were working up to skirts.
Was talking to another tiler in the pub last week,he said exactly the same thing to me about the same tile,said they were a right pain :(
H
Hlm
Sometimes I can get the cut straight with a combination of a few scores and tapping both ends, but I think the wet cutter will be the best option for the longer cutting.
Thanks for the advise.
beanz
Berkshire
That's a worry... My sole reason for wanting a Sigma, is that the Rubi cutters struggle with some of the porcelain tiles I've used, and I end up having to wet cut everything. If a sigma can't cut em either, am I just going to be throwing good money after bad! :-/
widler
1,328
England
Don't know mate, i use a rubi tx700, but the other tiler was a sigma user and i know phil hobson had some bother with some porca tiles which nothing would touch.
The Legend; Phil Hobson RIP
Certainly did Craig, they were glazed porcs, Andy Carrol has the top of the range Sigma manual it would not touch them, we ended up using a Rubi bridge saw.
widler
1,328
England
I remember it well, the 'cracked tile mystery' at mr wagstaffs? Job .
But some tiles are getting silly, i had some porca crack in more or less the same place, everytime before and like you used a wet saw .
Ken Bruty
1,003
Bedford
I've had the odd porcelain cutting probs too, I also have a sigma and made all sorts of adjustments to the gantry, sometimes it works if you turn the tile 180 deg after the initial scoring and scribe the top end 30-40mm then come back down and break the tile about 25-30mm from the other end near the measuring bar and instead of pressing down on it to break it, put a slight pressure on then crack the handle one firmly with the palm of your hand quickly so that the whole tile hardly flexes, this usually does the trick for me :smilewinkgrin:
I know this is an old thread, but just to chime in... I have a big clinker that I've put a brand new wheel on. Having the exact same problem with the porcelain tiles I'm currently laying, which is why I'm now using a wet cutter for everything. My big clinker was mostly trouble free when I did porcelain tiles 6+ years ago in my old kitchen - the tiles were cheap ones off eBay then too, the current ones are relatively expensive.
Jason T
My clinker was doing great, cutting with light pressure score and breaking very cleanly then suddenly it started chipping the glaze? bits popping off after its scored? heavier pressure is slightly better but its still popping off in places. These will look bad when I grout. tried various adjustments and 2 new wheels but no joy. Any ideas?
Reply to Big clinker and porcelain tiles problem in the Canada Tile Advice area at TilersForums.com
