Discuss Travertine advice needed please? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
SWANK1982
Hi,
I have just had 40m3 of travartine tiles laid in opus pattern in my kitchen. The tiler was arranged by my kitchen fitter. Can somebody please give me some advice on sealing and what is the norm. The tiles were sealed individually before they were laid with 1 coat of lithofin impregnator. How many coats are recommended and should they be recoated again along with the grout?
Any advice would be greatly appreciated on what you guys do normally.
Reply to Travertine advice needed please? in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
  • Question
  • Question
Hi! I'm looking for some advice, I have laid some SLC (Mapei 1210) in our conservatory in preparation for tiling. A couple of days after there's a lot of very fine cracks which have appeared, you...
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
