Discuss Expansion joints in screed in the DIY Tiling Forum area at TilersForums.com.
Joel DIY
Subscribed
N3, London
If they are conected then a soft expansion in the doorway if separate then you dont need to worry
they are separate rooms not connected and running independently with their own mat and thermostat.
I will leave an expansion joint at the door way but am concerned about the screed has nowhere to move against the walls.
Reply to Expansion joints in screed in the DIY Tiling Forum area at TilersForums.com
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
  • Question
