Discuss Laying large limestone tiles over UFH in the Tiling on Underfloor Heating area at TilersForums.com.
Schoolrunmum
Hello all,
We had a wet self levelling screed floor pumped into our kitchen back in October. UF Heating has been running well since. Just ordered 900x600 limestone tiles and need advice on prep before laying them. We have been told various things, conflicting too. Do I need to seal/prime the floor? Do I need a decoupling membrane? Do I use a fast or slow drying adhesive? Do I use a flexi adhesive?
Thanks in advance!
Ajax123
1,213
Lincolnshire
I assume when you say pumped self levelling screed you mean something like Gypsol. If so...
Turn off the underfloor heating for 48 hours and carry out moisture test to make sure its dry. sand and vac the floor to remove any loose friable laitance or other contamination. Prime it using an acrylic primer and stick an uncoupling membrane down using a gypsum based adhesive. then stick your tiles to this using a flexible adhesive suitable for the application and grout with a flexible grout. clean off and seal tiles once adhesive and grout are fully dried.
the gypsum adhesive is a medium rapid setting with a pot life perhaps 40 minutes to 1 hour. on top of the uncoupling membrane rapid set or standard set is largely a matter of personal choice.
Schoolrunmum
The guys that laid it tell me its TS40 by Gypsol, if that helps..oh, and the tiles are being delivered tomorrow, but will have to stay outside till we lay them. Snow forecast here tomorrow, is cold likely to crack them or anything?? Also, can anyone recommend an acrylic primer?
Ajax123
1,213
Lincolnshire
that's interesting as TS40 is not a mix. there is TS20 and TS15 but no TS40??? how deep is it? is it on insulation?? Who Laid it??
Ajax123
1,213
Lincolnshire
Hi Alan, apparently it's Classic...laid by Southern Screed..it's 50mm on Kingspan 80mm approx with wet UFH x
that's fine. I know they don't make a TS40 cos I work there... Classic is just the normal all purpose screed so treat as per advice above.
Ajax123
1,213
Lincolnshire
with ufh it must be flexi as you will get differential thermal expansion and contraction and uncoupling is a specific recomendation of the british stone federation. i agree with widler... go with the one who says flexi and uncoupling as he at least sounds like he knows what he is talking about. slow or standard set means you would not be able to traffic the tiles or grout them for at least 24 hours. i dont do much tiling myself and then only for myself but even so i prefer rapid set
Schoolrunmum
Thank you all for the input-last question, I have been told I need to seal floor with a polymer primer...can anyone recommend one? A google search comes up with a Wickes own brand one- wickes Primer and Admixture, a copolymer based on n-butyl acrylate and styrene, and a BAL APD acrylic primer. Are either of these suitable?
Reply to Laying large limestone tiles over UFH in the Tiling on Underfloor Heating area at TilersForums.com
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber floor in our barn conversion. The area is large, 21m x 8m. Having spoken to various UFH suppliers I...
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed most of our floor to accommodate tiling 800x800 porcelain over an uneven floor. The gap from defrac...
  • Question
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
  • Question
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent bathroom (600x600 porcelain, about 25m walls and floors) which went pretty well. I'm now having a go...
