Discuss Why Not Say Good Morning Before Work? in the General Off-topic Chat (nothing tile) area at TilersForums.com.
Status
Not open for further replies.
Why? Because you're not a plumber/ carpenter/bathroom fitter?
Serious question, I can't see in the pictures why it couldn't come out. Surely it would have saved so much time and stress even if it was, for some strange reason, awkward to remove.
.....Good morning!
Yes good morning Paul!......
And as you were so polite as to ask nicely, I'll answer you. :)
The builder in his infinite wisdom thought that the unit and sink were so heavy that he first bolted the carcass to the wall, adding extra cross members at the back and Chem fixing the bolts in, issue 1.
Then........ he placed in the sink, and proceeded to chem fix in two more bolts thro openings in the back of the sink. Even with the nuts undone, the sink won't pull forward enough to clear the bolts to enable you to lift the sink up and out.
Is that a satisfactory answer for you? :D:D:D
Doorway.?
Bath wall?
Centre line of the floor for it to wrap up walls, if you didn't, the grout line would not be at the same level on both sides of the room.
where Gary told you:)
Smart arse!
Status
Reply to Why Not Say Good Morning Before Work? in the General Off-topic Chat (nothing tile) area at TilersForums.com
  • Locked
I spend some time in doorways. TJ's Doorway Mosaics for McKenzie Shop Front
  • Poll
  • Sticky
