Discuss Which adhesive would you use do I need an S1 adhesive? in the Tile Adhesive / Grout Advice area at TilersForums.com.
Hi
I am renovating my house here in Italy, in the spring I took up the existing floor screed on the first floor and have installed a wet UFH system.
This was screeded using a self-levelling cementitious product from Fassa Bortolo called SA500. The screed was laid on the 23rd May to a thickness of 30mm above the pipes so 50mm in total, it is reinforced with a steel mesh. In terms of flatness and level the finish is very good. The floor has had the summer to dry and it has shrunk away from the contraction joints as anticipated. The first floor uses a typical Italian slab construction of terracotta pots and reinforced concrete (see photo), it is pretty stiff but of course there will be some deflection / vibration.
The tiles we have selected are 600 x 600 x 10mm rectified porcelain, the two main areas are 25 and 18m2 respectively plus an area of corridor 54m2 in total. I will sand the screed in preparation for tiling and was planning to use a 10mm notched trowel, back butter the tiles and use levelling spacers but would appreciate your advice here. I would prefer not to use a decoupling membrane.
I am looking for some advice on adhesive, the main suppliers here are Mapei and KeraKoll but Laticrete, Weber and Fassa Bortolo are also available. I can buy Fassa Bortolo AZ 59 Flex, which is an S1 adhesive at a good price if anyone has experience of this? AZ 59 FLEX - Adesivo monocomponente a buona elasticità, bianco e grigio, per pav - Fassa Bortolo - http://www.fassabortolo.co.uk/en/product/-/p/10/3359/adhesives/az-59-flex-one-component-adhesive-with-good-elasticity-white-and-grey-for-both-exterior-and-interior-floors-and-coatings
I am looking for a nice adhesive to use, no need for rapid set. Whilst I am not a tiler I started my career as a plasterer before moving into project management so I have a good understanding of construction and I can make a good job of most things.
By the way what constitutes a large format tile?
Many thanks in advance.
I
Italy
Many thanks to you both. I know Kerakoll H40 No Limits well I have been using it recently so I am happy to use this.
Am I correct in using a 10mm notched trowel and back butter the tiles, the tiles are 60 x 60cm porcelain? YES
Antonio which grout do you prefer the area is kitchen / dining and its a heated floor? THE NEW FUGABELLA COLOR 50 available colours
2mm joints? YES
Grazie mille, buona giornata
ANCHE A TE :)
Reply to Which adhesive would you use do I need an S1 adhesive? in the Tile Adhesive / Grout Advice area at TilersForums.com
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
