H
hmtiling
It will show but won't poke you in the eyes as it does nowThe ceiling is out by 20mm...... It will always show on 200x100 tiles
Discuss Tiling Standards (BS 5385) | British Wall and Floor Tiling Standards - IN FULL in the UK Tiling Forum area at TilersForums.com.
What I mean is, still using the same size tile as I have, I understand that I would have had a 20mm graduation but if he had set out probably the final tile would have been a larger cut so not do noticeable?It will show but won't poke you in the eyes as it does now
Am I the only one who thinks the ceiling should be level? Why spend all that money and have a poor finish?
Haha Thanks @3_fallRegardless of the fact that the ceiling may be out of level, if you tried that set out on site, you’d be lucky not to be swinging from the scaffold, but I suppose more likely sent off site never to return or be paid.
Good practice is to have at least one third of a tile as a cut, some QS want larger, but a third is generally acceptable.
Last time I was on site anyway.
And as far as a full tile off the bath goes, if we did that, 90% of our work would be out of level.
No but 99% of the tilers on here keep banging on about how things are done .... blah blah blah .....so why not go ape about the ceiling like you would do if the walls were not plumb and flat.No you’re not Tom, do you refuse to tile a room then if the ceiling isn’t level? Haha
Reply to Tiling Standards (BS 5385) | British Wall and Floor Tiling Standards - IN FULL in the UK Tiling Forum area at TilersForums.com
