Discuss Tile Adhesive Poll 2013 - Which Tile Adhesive Did You Use Most? in the Canada area at TilersForums. The USA and UK Tiling Forum (Also now Aus, Canada, ROI, and more)
Gazzer
Which Tile Adhesive Did You Use Most During 2013?
Please vote on the Poll. All answers can be seen by the members.
If you used a brand not showing then please respond with the make.
It might be due to trust, availability, customer preference, whatever. Just if you totted up the lot you used, which one did you use and buy the most of ?...
This is for 2013 only
ALL TILE ADHESIVE POLLS - WHICH TILE ADHESIVE BRAND DO YOU USE THE MOST?
johnryan
i ticked weber as i use that the most (60-70%) but still use ardex and mapei a fair bit too. would try tilemaster too if i could find somewhere local to get it.
jonnyc
oh look at tilemaster go.!!
i have used it exclusively now for last year or more since gary put me on to it.
Gazzer
I predict Tilemaster will do very well at the cost of some of the top brands and this will make a big impact on the overall result. I say they will triple last years votes.
I
Ian
Weber is what I've used for 80% of my work this year. I have done about 250 m2 of anhydrite this year and used anhyfix from tilemaster for that.
jonnyc
thought some might be interested to know why i changed to setaflex white last year.
apart from cost which is one key as probably use about 40-45 palletts a year just adhesive, mark of tilemaster talked to me about what i was after in an adheisve .
I explained good workability and non slumping with thick bed under quite heavy stone but most importantly needed to be able have enough time to adjust a large module of stone say 4.00 mts/ a long course of stone or uneven sized reclaimed .
We would need an hour or more sometimes but it was still imperative that the adhesive was a fast set and dried within its self so moisture not migrating up though stone.
he then said that he could manufacture retarded fast which would give ius that time especially in the summer.
i tried it out and that was the clincher for us as stonefixers.
you do need to make sure ok to walk on next day but then the rapid setting procedure kicks in and this helped me so much.
does anyone know anyone else doing this because i dont
Reply to Tile Adhesive Poll 2013 - Which Tile Adhesive Did You Use Most? in the Canada area at TilersForums.com
Dawz84
