grinder
Hi guys
I need some advice as to how to remove the flange in the shower floor so I can re tile my shower base as per photographs.
I'll be grateful for your advice as I do not want to break the exiting waterproofing. Should I remove the ring with a grinder or look for an adapter to place the new grate over it?
Thank you guys
PS Oh BTW the diameter hole is 75 to 80 mm not taking into account the ring around the tiles if that is then the hole is 100mm diameter.
I thought to carefully chip off the tiles around the ring and grind the ring so it may come off then insert the new flange sealed with polyurethane silicone and continue tiling over tiles.
i wonder if that is the correct method provided the ring comes off without much work.
Now i found an 80 mm opening but not sure if it fits right into the pipe and silicone or waterproof it
Thank for your help guys
Thank you guys
