richmondhall
Hi
Done floor, now for the walls.
Tiling 600x300 porcelains onto mixture of sand\cement mortor and tilebacking board(overboarded)
Using bagged flexi adhesive
Questions:-
1. What size notched trowl is best for these size tiles?
2. Should I be 'back buttering' the tiles as well as trowling the wall, and if so is that simply a thin flat coatuing of adhesive?
3. Finally, when cutting (using a wet cutter) the edges splinter, has a new blade, not bad and for most part grout can cover, but is this normal please?
Just want to make sure these things stick and stay stuck - and not fall off onto my lovely tiled floor!!
Many thanks in advance
Questions:-
