Discuss Nicobond Rapidflex confusion..... in the UK Tiling Forum area at TilersForums.com.
Gazebo
Hi again.
Hope you are all keeping well, just a couple of things i need help with, i purchased 2 bags of white nicobond rapidflex, being unsure of which (if any) substrates need priming i thought i would ask in here for clarification, 1.Knauf Aquapanel (dont think i needs priming)
2.Green moisture resistant plasterboard.(think it does need priming.)
3.lime plaster wall, (only going up 1.2m high)
Tiles are basic 250mmx200 ceramic, only other thing is where i got the nicobond from the only primer they had was 'Palace tilers primer' will this be ok if anything needs tiling,
Should i take the nicobond back and get a Bal rapid set Spf. with some Bal sbr?
I actually contacted nicobond(they were not very helpful put me onto sales instead of the tech dept, said they would phone me back never did. So i had to phone them again and was told that i could not tile onto green (moisture res)plasterboard with this product, aquapanel was fine, normal plasterboard was fine, but not green pb. So now i am confused.
HELP.
Cheers:8:
Gary
Gazebo
Why don't you use White Star for all of the walls, either to use, great product. Flexible, highly white and don't need a primer.
I do normally use white star with this size tile but needed to grout the next day, as i understand white star needs longer to set than spf. how long do you leave white star as a rule before you grout, then how long do you leave the grout before you silicone.? do you advise the customers how long before they use their shower .? if so how long....
jeez just how long is long.?
Gary.
Reply to Nicobond Rapidflex confusion..... in the UK Tiling Forum area at TilersForums.com
