Discuss Myson Micro Board piped heating boards.. in the Tiling on Underfloor Heating area at TilersForums.com.
Evening all,
Just been to see a job where the customer is wanting to use this system over existing concrete floors.
New one on me and had a quick Google but all Myson literature is very basic and vague.
Anyone had any experience of it?
If so, is it just an adhesive fix down to a satisfactorily flat floor?
MicroBoard by MYSON - http://www.myson.co.uk/products/microboard.asp
Are you fitting it merl?
Sorry I don't know you very well so I don't know if you have a plumbing background.
It just looks like Polypipe overlay to me.
You'd need to find out if it's a gypsum based or cement based board, then you'll know how to prep it for tiling.
I agree, their tech sheet is next to useless! Haha
Im not doing the plumbing element of the works but ive said id rather prep the concrete and install the boards for the plumber to pipe it up prior to tiling. Do you adhesive fix the Polypipe boards?
Looks virtually the same except colour Julian.
The plumber is supplying the system so would rather leave it to him.
Do you need to self level over the pipes before tiling?
If you get the chance, pressurise system before the slc, that way when slc dries and system is drained you'll have a little room for expansion of pipes down the line. Pressurise as high as you can.
Will be installed alling the boards and leaving to for the plumber to pipe up and commission mate, then will return to SLC and tile. Cheers for the tip.!
Reply to Myson Micro Board piped heating boards.. in the Tiling on Underfloor Heating area at TilersForums.com
Good afternoon, Does anyone have experience of using grooved dry screed boards? (Bonus points...
I am sure someone will know a good practice solution. We started a wetroom last year and then...
Hi there, Has anyone had any experience with this product and what was you opinion on it? I’m...
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Underfloor Heating Trending Threads
    Votes: 5 5.0%
    Votes: 8 8.0%
    Votes: 6 6.0%
    Votes: 24 24.0%
    Votes: 14 14.0%
    Votes: 28 28.0%
    Votes: 3 3.0%
    Votes: 2 2.0%
  • Tilemaster /Kelmore
    Votes: 19 19.0%
    Votes: 18 18.0%
    Votes: 11 11.0%
    Votes: 5 5.0%
    Votes: 3 3.0%
