Discuss my wetroom in the Tanking and Wetrooms area at TilersForums.com.
Ajax123
1,213
Lincolnshire
nice to know Im buying well... mind you ive spent nearly £30k with my timber merchant in the last 18 months so I would expect good prices... I have no idea where they source their timber but where Ive needed C16 they have always supplied C24, their fence panels are really cheap but use 18mm feather edged board as opposed to 10mm which is standard for the likes of wickes etc... all in all they are a pretty god supplier
Ajax123
1,213
Lincolnshire
Im getting close to the point now where I wil be putting in my wetroom tray. Bought Marmox in the end as got a really really good deal on it. I need to stick it down to the plywood. SO my question... what adhesive should I use. Standard set flexi, rapid set flexi, something extra special. and what primer... is there a special primer for plywood. If it were screed I would know...but its not so Im asking.
Also I have purchased some natural slate from Walls and Floors for the floor along with some sealer... do I use the same addy for those... and finally I bought Mattstone sealer... from memory this goes on before grouting then again after grouting...is that right.
thanks in anticipation as usual...pictures will follow shortly.
One Day
Alan, I'd use any old S1 adhesive to stick the tray with. 10mm notch, nice wet mix and back-skim the tray.
Rich Midge
598
Liverpool
Usual logic applies, try to stick with the same manufacturer throughout the process. Prime every edge and face of the ply not just the surface receiving the tiles. I'd go with an S1 rapid addy. LTP Mattstone is a good sealer but imo there's better out there. You'll most likely need to reapply every couple of years at least. DryTreat Original is a fantastic impregnator, and don't forget @Lithofin BOB. They do some superb products, from cleaning through to sealing.
Ajax123
1,213
Lincolnshire
cheers Impish... Will probably use something from Tilemaster or Norcross... Although given that I will only need probably one or maybe two bags I might well just get some mapei from B&Q.
Impish .... thanks... I will be doin every thing I can to make it work. I am buying very aggressively generally but wont cut corners on the installation. the mattstone sealer came with the tiles so was also a very good deal...
Lithofin BOB
508
Hampshire
Your mattstone ,should be fine for this instalation
Once all moisture is released from the instal , 1-2 saturations, remove all excess
Let cure ,12-24 hours
Check grout release
Grout, once fully dry, final application to impregnate all.
Reply to my wetroom in the Tanking and Wetrooms area at TilersForums.com
  • Sticky
