bureaucrazy
- 178
What is the best way to tile round a bath?
Basic stuff pros take for granted but is not obvious for me! The subfloor is t&g floorboards and I will use 6mm backer boards. The walls are cement render.
Q1) I was thinking it is better to tile down to the top edges of the bath so the tiles ovelap and the top of the bath is a little underneath the tiles as this would be more waterproof than tiling the wall and then pushing the bath up against the tiles (and then sealing with silicone). Am I right?
Q2) I have ready made plastic bath panels and they are the same length as the bath but have a bowed/curved cross section how they are molded.
Fitting the bath panel first and then tiling up to it would not be easy for me. Plus, I might want to fit a flat/straight panel later so do not want the tiles profiled round the curved panel. What is the best overall approach to take care of this? Is it better to trim the panel and tile behind the panel but still tile around the top of the bath. (The panels do not look designed for trimming and keep their shape due to the way it is molded at each end.)
Q3) Floor. There needs a 2X2 baton screwed along the floor to fix the bottom of the bath panel. Should I fit the panel and then tile up to it or tile right up to the baton so that the bottom of the panel comes down onto the tiles?
Q4) The panel has a lip on the bottom, should the batton have a corner cut out all the way along so it over hangs and the panel lip will fit under?
