Discuss How much should I worry about this? in the America Tile Forum area at TilersForums.com.
58
Washington, DC
I just set new porcelain 8 x 8 tile in my rear entryway (3 ft x 3 ft area). I love the results and wanted everything to be perfect and by the book. So, these two things are worrying me.
Worry #1: One of the tiles is touching a door frame in a couple of spots (see pic). The door frame is metal by the way (weird in a house, I know). There is at least a 1/8 inch gap elsewhere, and on two sides there is a good 1/2 inch that will be covered with baseboard. Is this tile going to pop off or crack in time, or is that not really a concern?
Worry #2: Where the tile meets the top of the stairs, it overhangs the Hardiebacker very slightly (see pic). Maybe 1/8" is unsupported along that last row of tile. There will be a wooden piece in from of that flush with the tile, so it would be impossible to stand just on that 1/8" bit that's sticking out, but I'm still worried it could chip or lossen. I was thinking maybe I should try to get a tile file and file off 1/8" all the way along, or maybe I should buy some expoxy putty and press it under there. If I did that, the epoxy would be resting on wood, and I wonder if that might cause other issues. Thoughts?
Thanks in advance for you're help with this.
58
Washington, DC
Thanks, so no room for expansion is okay as long as it's just in a few spots? Also, won't the grout just fall out in that last 1/8" that hangs over (using epoxy grout)?
Reply to How much should I worry about this? in the America Tile Forum area at TilersForums.com
